I click mouse anywhere in the note, it shows the cursor below the click (1 line below). Also when i press UP arrow to get into the line above it throws me to the above 2-3 headings before. (down arrow works fine)
Please help anyone.
I am using Parrot OS, Linux.
And yes, when I restart obsidian, it works fine for at least few minutes. But later it becomes the same as i described.
Please follow and include the template when posting in the bug reports category, thanks!
It’s possible a theme or css snippet is changing vertical margins in the editor? If so, you can see behavior like that.
I moved this to help section. If you open a new BR please follow the template. thanks
