Css for changing padding / margin for latex/math
I am trying to reduce between normal text and the math environment.
Anyone knows the CSS?
example:
text before the double dollar env
$$\begin{flalign}\begin{cases}
x = xxx \\
x = xxx \\
\end{cases}&&\end{flalign}$$
Looks like in editing mode, that’s being set via padding (specifically, on .markdown-source-view.mod-cm6 .math-block > mjx-container).
In reading mode, it’ll be slightly more work, since it’s being controlled by the margins of both the element before the math environment (such as a p element, for example) and the element of the math environment itself (mjx-container[jax="CHTML"][display="true"], when I tested).
