Proposal
Be able to synchronize and maintain a specific file between two different vaults. Any update in that file in one vault will update the linked file in the other vault.
For these specific files, it would probably be appropriate to automatically maintain all Obsidian links as Obsidian URI links.
Use case
It makes sense to use a separate vault for certain projects or vastly different ares of life, like PKM and professional work documentation. However, there are often a few inevitable documents that crossover between two knowledge bases that should otherwise be separate.
It would be nice to be able to maintain these few crossover cases from either vault.
Workaround
- Make a tough choice about which vault should should hold that file.
- Wherever that file would be mentioned in the vault that doesnāt have the file, use an Obsidian URI link.
You donāt get any backlink navigation or insight. And any links to the excluded vault would have to be manually maintained as URI links as changes happen.
