Creating code blocks with dataviewjs
I’d like to be able to generate code blocks from dataviewjs.
i.e. generating the exact same output as something like:
```python
print("Hello, World!")
The documentation lists a few methods like header or paragraph, but nothing for code blocks.
I’ve tried creating a simple code block:
```dataviewjs
dv.el('code', 'print("Hello, World!")', { cls: 'language-python' });
I also tried replicated the HTML output of a code block:
```dataviewjs
const txt = 'print("Hello, World!")';
let pre = dv.el('pre', null, { cls: 'language-python', attr: { tabindex: '0' } });
const code = `<code class="language-python is-loaded">${txt}</code><button class="copy-code-button">Copy</button>`;
pre.innerHTML = code;
But both end up with outputs that don’t look the same as a regular code block.
Does anyone know a better way to do this?
What about:
```dataviewjs
dv.paragraph('~~~python\nprint("Hello, World!")\n~~~')
Thank you! This did the trick.
It seems like I was overthinking it.
