Trying to create a base filtered depending on a property value
Tried creating a filter in the format property == {{property_value}} from the current note, but I get no results. The property in question is a string but contains links to other notes in the form [[link_to_other_note]]. In markdown this value is stored in the current and target notes as “[[property_value]]”. I don’t know how to format this query. Doesn’t work with operator is or contains. Thanks in advance if you can help.
