I’m trying to move the content that I make from vault A to vault B. The problem is some of the content in vault A have the same file name with vault B so it produce incorrect backlink.
For example, if I have Vault A & Vault B like this :
Vault A
|_ daily-notes
|_2021-05-11.md
|_other-contents...
Vault B
|_ daily-notes
|_2021-05-11.md
|_other-contents...
and I want to move it to Vault B as a folder :
Vault B
|_daily-notes
|_2021-05-11.md
|_Vault A
|_daily-notes
|_2021-05-11.md
|_other-contents
|_other-contents
Some of the file that contains link [[2021-05-11] will refer to the Vault B one, while the Vault A need to be referred as [[Vault A/daily-notes/2021-05-11]]. But the problem is when I just move it directly from file system it can not change the link path.
Is there a way for the file that we merge/import from other vault automatically updates so it does not break the original backlink?
Edit :
I found that I can change link format in File & Links > New Link Format and change it to relative path instead of shortest path. It’s nice that it can solve this problems if I want to merge another vault in the future, but I wonder if there’re ways to :
- Change all link that already exist in the vault into the relative path format
- Display the text using the filename automatically, so instead of
[[../daily-notes/2021-05-11]], it can automatically format it to [[../daily-notes/2021-05-11|2021-05-11]] since I don’t like to see entire path of the file when reading it if possible…
