What I’m trying to do:
Go back to default Core settings for Daily Notes.
Can’t seem to find help for this in the Obsidian Help page.
i.e., Reset to Default.
There are only 4 options. The default values are 3 empty fields, and the 4th checkbox turned off.
You can open the Sandbox vault to see the default values.
Close Obsidian first. Inside YourVault/.obsidian/
you can delete the daily-notes.json
file. That would also reset the settings.
Thanks, worked well!
