Copy and paste from DuckDB no longer formats correctly
Install DuckDB
In a terminal
$ duckdb
D create table foo (id INTEGER, name VARCHAR);
D desc foo;
│ column_name │ column_type │  null   │   key   │ default │  extra  │
│   varchar   │   varchar   │ varchar │ varchar │ varchar │ varchar │
│ id          │ INTEGER     │ YES     │         │         │         │
│ name        │ VARCHAR     │ YES     │         │         │         │
Copy the result table from DuckDB and paste it into Obsidian.
Prior to the most recent update, the table would be correctly formatted.
See screenshot.
Restarted Obsidian, picked up version 1.7.7 apparently, things look ok again
	Obsidian version: v1.7.7
	Installer version: v1.5.12
	Operating system: Darwin Kernel Version 23.6.0: Wed Jul 31 20:50:54 PDT 2024; root:xnu-10063.141.1.700.5~1/RELEASE_ARM64_T8122 23.6.0
	Plugins installed: 1
	Plugins enabled: 1
		1: Obsidian Git v2.19.1
You may want to consider downloading and reinstalling Obsidian fresh. There are a few installer versions that introduce changes (CodeMirror and security updates) that can’t always be auto-updated.
