We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
I’m copy pasting article from Web (Wikipedia) with a lot of links, some formatting and some headers. Behavior of iOs and macOs programs is different. When I copy-paste at desktop - obsidian converts all links and formatting into mark up and obsidian links. I do not like outcome.
When I copy-paste same article at iOs (from Safari) - obsidian do not respect links and markup, and produce almost plain text. I like the outcome more.
There shall be an option page for copy-paste operations with the following switches:
- convert headers
- convert italic/bold formatting
- convert links
There will be a possibility to control behaviour of copy paste function and exclude certain elements.
I like iOs copy-paste function, so I make copies at iPad, and then add some header formatting.
There would be great, if image download function will work with copy paste, and there will be another control to enable/disable image downloading.
