- open help vault
- go to
Settings > Editor
and turn on spellcheck - create a new document and type a misspelled word followed by space:
Refference
- arrow over so the cursor is inside the word
Ctrl/Cmd-P
and choose Show context menu under cursor - A context menu will pop up suggesting
Reference
as a replacement. Select it (using keyboard) and hit Enter.
The misspelled word should change to Reference
The misspelled word does not change.
Note that if you right-mouse click on the misspelled word and choose the correction with the mouse, it does work.
This happens with native menus on and off.
- Operating system: MacOS
- Debug info:
Obsidian version: v0.16.2
Installer version: v0.15.8
Operating system: Darwin Kernel Version 21.6.0: Wed Aug 10 14:25:27 PDT 2022; root:xnu-8020.141.5~2/RELEASE_X86_64 21.6.0
Catalyst license: vip
Insider build toggle: on
Legacy editor: off
