Setup:
- Ensure live preview mode is enabled
- Enable the command palette
- Create a callout like the following
> [!Note]
> Hi
Issue:
- While your cursor is focused in the callout…
- Open the command palette
- Select
Show context menu under cursor
The callout menu should appear, the behavior if you right click with the mouse
No callout menu appears and the cursor changes to a different line
- Operating system: Windows 10
- Debug info:
Obsidian version: v1.0.3
Installer version: v0.15.9
Operating system: Windows 10 Home 10.0.19043
Legacy editor: off
