rigmarole, thanks for the updated CSS snippet! I hope the Obsidian developers will make this more flexible in the future.
I can suggest another design option (I prefer it without stripes or waves under the text, and the unresolved link text itself should always be a nice, soft red color across both versions of the Obsidian theme):
Currently, there are two options when clicking a non-existing link:
Create note in root folder.
Create note in same folder.
My vaults consist of many folders, with notes that contain many links.
I never want to create a new note in the root folder, and I almost never want to link to a note in the same folder as the current note.
Please note that my workflow involves clicking on these links a lot. When I click on a non-existing link, I want Obsidian to just tell me that the file doesnāt exist.
Since this feature is not popular, it should not be the default behaviour, but it would be preferrable to have this available as an optional setting:
Do not create new note when clicking on a non-existing link.
Current workaround
A suggested workaround that I have found is:
Not clicking on non-existing links. This is not an acceptable solution for me, because I donāt want to be āpunishedā for clicking on links too quickly, and I never want to create new notes by clicking on links.
Related feature requests
Related posts I have found: (please note that none of these posts are 100% same to this one, this feature request asks for an option to completely disable current behavior in all cases)
Good idea! Another workaround is to include the path in your link so that worst comes to worst and you accidentally click the link, at least the note will be created in the correct folder.
For example, [[software/houdini]] would create the Houdini note within the software folder when clicked. And if the software folder doesnāt exist, it will be created. I understand this is likely not the solution for you, but thought it might be worth sharing just in case.
Itās shocking that we have no way to manage this.
We need full control with three settings options:
Ask whether to create a new note.
Create a note without asking.
Do NOTHING when clicking a link (at most, make it visually red when hovered over and āshakeā visually when clicked).
This is important for situations where I want to prevent other users or myself from accidentally creating unnecessary entries, especially entries in the wrong place.
Furthermore, this is extremely harmful behavior ā I donāt want random files and folders appearing in the knowledge base in unexpected locations if links have a relative path (and, for example, point to a location OUTSIDE the current Vault). This is especially true if Iām creating a distributed knowledge base (for example, by having vaults located next to each other in the same folder/repository or nested within each other (though this is less common, to avoid errors)āand Iām intentionally manually creating relative links between records in different vaults). Because now, clicking on a non-existent link (within the current vault context) creates a FOLDER OUTSIDE THE VAULT, which shouldnāt happen!
