There is a lot of useful plugins. We do not know which one will work on a current version of Obsidian or whether it will work on Obsidian Mobile.
Add metadata to the plugin, telling us which version a plugin will work.
Based on this data, You can add a filter to Obsidian to show only compatible plugins.
We can find it only by installing a plugin and checking manually or entering a developer site (usually GitHub) and finding info in the Issue section or the description.
