Commonmark-compliance: Reader should not parse intra word underscore
Steps to reproduce:
Copy and paste 字体_斜体_字体*斜体*字体
Actual result:
Expected:
this is not a bug
https://spec.commonmark.org/0.30/#emphasis-and-strong-emphasis
Hi,
The “actual result” was the result from live preview, and the “expected” was the result from reading mode and the output file. The two results are inconsistent.
The two results are inconsistent. I guess the two modes use different parsers. You can say this is not a bug for its specific implementation, but I consider the inconsistency a bug.
And btw do you consider this a bug?
Copy and paste 啦。**啦。**啦。
The result in live preview:
From the website you cited, “Many implementations have also restricted intraword emphasis to the * forms”, so the asterisks here should work, right?
According to commonmark spec, The bug is in the reader, non LP.
This is a whole other can of worms related to how markdown should handle Chinese special punctuation characters.
How about not making the full stop bold?
啦。。啦。
啦。**啦**。啦。
Or using a zero-width space after the full stop (not sure if that will copy and paste here correctly)? Both parse.
啦。啦。​啦。
啦。**啦。​**啦。
Hi,
Thank you. These are good workarounds!
btw, how did you type that zero-width space?
On macOS: Edit → Emoji & Symbols → insert the zero-width space.
