Color-accent variable only works in light mode, why?
–color-accent: #fff !important; --color-accent: #fff; doesn’t make a difference, it only shows up in light mode, in dark mode it gets overridden by the accent in the main settings. (#fff in this case is a placeholder, it’s a visible color either way.)
please reply, this is making me insane and AI doesn’t help either, nothing works…
–color-accent-dark or --dark-color-accent also doesn’t work apparently. and like i said, the !important makes no difference. it simply doesn’t override the dark accent no matter what i try. the codes for light mode and dark mode are literally the same just with different colors (not counting the accent which is supposed to be the same in both)
someone on discord solved this together with me. no more replies required
