Collapsed headers opening when I don't tell them to
I never had this problem, but suddenly when I do something like paste into a bullet point, a collapsed header or bullet point below it will suddenly open up and show everything inside. I didn’t ask it to open up. I don’t want it to open up unless I tell it to.
Example:
  • blah blah
  • (I paste something)
this header is collapsed before I paste something
  • now all of the stuff inside is visible because after I paste above, the header is no longer collapsed
I scanned through the changelog and settings, I searched “collapse” and looked around.
EDIT: it seems inconsistent too, like if I paste “change test” it’ll open the below header, but if I paste “the bomb” it won’t. ???
moved to help for not following bug report template
