Some of the code is displayed correctly:
The code is just below:
Same with the image:
A little lower down in the same post:
The <T>
is most likely breaking everything after it.
Obsidian thinks that’s HTML and it’s not closed properly. You can write it as inline code and it should be fine:
...Model`<T>`:
https://help.obsidian.md/Editing+and+formatting/Basic+formatting+syntax#Code
thank u very mutch
