Сan’t insert multi-line code inside note(code input field captures underlying text).
there is a note, I try to add code inside it, ``` adds a code input field, but immediately the underlying plain text (not code) is dragged into this input field …
Do you have the corresponding 3-backticks to end your code field before whatever text is getting dragged in? I usually make both the beginning and end 3-backticks on consecutive lines and then start typing in the middle to avoid text below getting transformed into code.
