Insert a fenced code block. Set the language to aspx; ie the following without slashes,
\```aspx
Some stuff
(I have the Obsidian Nord theme, with Obsidian set to dark mode.)
Code highlighting for aspx.
A full crash of the edit pane, with “An error occurred while opening obsidian”. Only fix was to use an external editor to remove the code block.
  • Obsidian version: v0.12.15
I can’t reproduce. Post a screen recording of this happening in the help vault.
