  • create 2 files: file a and file b
  • move file a to be part of the right pane. I.e. having a fixed position underneath the other standard panes (tag, backlink etc)
  • open file b
  • move the editor focus to fixed file a (in order to edit it)
  • press CMD+ENTER in order to insert “- [ ]”
  • observe that the task notation is actually being added to file b
2022-03-15_102135
If a file is a fixed part of the right pane, then executing CMD+ENTER will actually put the task notation in that file
Executing CMD+ENTER in the right pane fixed file, will insert the task notation in an active other file.
  • Operating system: MacOS
  • Debug info:
    Obsidian version: v0.14.0
    Installer version: v0.13.31
    Operating system: Darwin Kernel Version 21.3.0: Wed Jan 5 21:37:58 PST 2022; root:xnu-8019.80.24~20/RELEASE_X86_64 21.3.0
    Catalyst license: insider
    Insider build toggle: on
    Legacy editor: off
    Safe mode: off
    Plugins installed: 5
    Plugins enabled: 0
A post was merged into an existing topic: Hotkeys \ commands should apply to sidebar notes when they are focused
