We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
Try to create checkbox with Cmd + Enter
Checkbox does not show up.
Create checkbox manually via Markdown formatting.
Use Cmd + Enter to “check” the box.
Checkbox is not “checked”, has to be checked manually via a mouse click.
Checkbox should generate or be toggled on/off when user presses Cmd + Enter hotkey.
Checkbox does not generate nor toggle with Cmd + Enter hotkey.
- Operating system: Windows 10 desktop app
- Debug info:
Obsidian version: v1.0.0
Installer version: v0.15.8
Operating system: Windows 10 Pro 10.0.19044
Legacy editor: off
Community theme: Minimal
Plugins installed: 46
Plugins enabled: 41
1: Fullscreen mode plugin v0.1.2
2: Advanced Tables v0.17.3
3: Todoist Plugin v1.9.0
4: Mind Map v1.1.0
5: Markdown Formatting Assistant v0.4.0
6: Editor Syntax Highlight v0.1.3
7: Reading Time v1.1.1
8: Recent Files v1.3.3
9: Toggl Track v0.9.0
10: LanguageTool Integration v0.3.0
11: Dictionary v2.21.1
12: Admonition v9.0.5
13: Paste URL into selection v1.7.0
14: QuickAdd v0.5.5
15: Note Refactor v1.7.1
16: JSONifier v1.0.1
17: Style Settings v0.4.12
18: Day Planner v0.5.8
19: Excel to Markdown Table v0.4.0
20: Find orphaned files and broken links v1.8.0
21: Pandoc Plugin v0.4.1
22: Image Toolkit v1.3.1
23: Custom Frames v2.4.4
24: Reminder v1.1.12
25: Better Word Count v0.8.1
26: CSV Editor v0.0.1
27: Jira Issue v1.31.0
28: Natural Language Dates v0.6.1
29: Shell commands v0.16.0
30: File Explorer Note Count v1.2.0
31: Google Tasks v1.4.6
32: Todoist Link v2.0.5
33: Todoist Text v1.3.2
34: Templater v1.14.3
35: Obsidian Git v2.6.0
36: Minimal Theme Settings v6.0.5
37: Copy button for code blocks v0.1.0
38: Vantage - Advanced search builder v1.4.2
39: Dataview v0.5.47
40: Outliner v4.1.0
41: Kanban v1.4.6
Thanks for taking care of this! I love Obsidian and this is the main feature that I use this app for. I am considering buying Sync (currently using Git). Without this shortcut, I will probably move on to Notion instead.
