Clicking pdf in split view does not focus pdf
  1. open obsidian sandbox vault
  2. create new folder
  3. put a PDF in the vault (I placed mine at root folder)
  4. open the PDF in a new tab. there are now two tabs: Start Here and pdf.
  5. click and drag pdf tab to open in split view
  6. click on text of Start Here tab to focus the tab
  7. click on the body of the pdf to attempt to focus the tab (issue)
  8. e.g. ctrl + f dialog in this state will open the find dialog on the Start Here tab, not on the pdf tab
workaround
  • instead of clicking the body of the pdf to focus the tab, click the tab handle at the top. now, ctrl + f and other actions that target the focused tab work as intended
  • in my main vault, I also have the command Focus on tab group to the left/right bound as keyboard shortcuts, and those keyboard shortcut still works. I didn’t try this in the sandbox vault, however.
Yes
pdf in split view should focus when clicked
pdf in split view does not focus when clicked
	Obsidian version: v1.8.4
	Installer version: v1.8.4
	Operating system: Windows 11 Home 10.0.22631
I don’t believe this was happening before v1.8.4, but I have not personally verified this.
Another workaround, right clicking the body of the pdf in split view focuses the tab. left click still does not, though.
I was having the same issue. Had to downgrade to 1.7.7 to make it change focus on left clicks.
Should be fixed v1.8.8. No ETAs
