- Create a note with an image.
- Cmd+Opt+Click (OSX) on the image (in Live Edit / Preview mode) to open it on the right side.
- Normal click on the image on the left side one more time so that its markdown code is selected.
- Click on the right window containing the image and press the keyboard shortcut to rename the current file (for me it’s Cmd+T)
I get asked to rename the image file.
I get asked to rename the note containing the image on the left side.
See attached video which shows that the focus doesn’t seem to go to the right window when the image’s markdown code is selected on the left side.
Screen Recording 2022-09-07 at 12.21.59.mov.zip (2.7 MB)
- Operating system: OSX
- Debug info:
Obsidian version: v0.16.2
Installer version: v0.15.6
Operating system: Darwin Kernel Version 21.6.0: Wed Aug 10 14:25:27 PDT 2022; root:xnu-8020.141.5~2/RELEASE_X86_64 21.6.0
Catalyst license: insider
Insider build toggle: on
Legacy editor: off
Base theme: light
Community theme: Minimal
Snippets enabled: 1
Plugins installed: 11
Plugins enabled: 10
1: Advanced Tables v0.17.3
2: Calendar v1.5.10
3: Find unlinked files and unresolved links v1.5.2
4: Hotkeys++ v0.2.7
5: Obsidian Git v1.27.1
6: Minimal Theme Settings v5.3.2
7: Style Settings v0.4.10
8: Electron Window Tweaker v1.0.8
9: Recent Files v1.3.3
10: Image Caption v0.0.13
Why I need to do this: I’m renaming image files based on the description I’ve entered (I’m using a community plugin called Image Caption, which isn’t causing this issue.)
Why it’s a problem: it’s caused my to accidentally rename notes several times.
