[CLI]something Wrong in using Obsidian CLI
I try to use Obsidian in CLI mode. But the following error message appears in terminal:
[6685:0325/093322.244455:FATAL:setuid_sandbox_host.cc(158)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I’m aborting now. You need to make sure that /tmp/.mount_obsidi8mf16K/chrome-sandbox is owned by root and has mode 4755.
Trace/breakpoint trap (core dumped)
Obsidian Ver: 1.12.7
Installer Ver:1.6.7
The CLI is already activated in Options->General->Advanced->Command Line Interface
The path settings were also confirmed according to the prompts.
You need to re-install Obsidian with the very latest intaller:
