CLI: problems with escaped characters (new line)
Two problem:
  1. Escaping an escaped character (\\n) doesn’t work from CLI
  2. Escaping a character (\n) doesn’t work from TUI
  1. Execute from CLI
obsidian  create path="test.md" content="text\ntext\\ntext" overwrite
or 2. within the TUI
text
text\ntext
  1. CLI
text
text\
text
  1. TUI
textntext
text
  1. Run obsidian create path="Inbox/cli-escape-repro.md" content="# CLI escape repro" overwrite.
  2. Run obsidian append path="Inbox/cli-escape-repro.md" content='plain nu: \nu'.
  3. Run obsidian read path="Inbox/cli-escape-repro.md".
  4. Observe the written note content.
N
I have reproduced the issue from the CLI, but this draft still uses my normal vault state rather than restricted mode or the Sandbox vault.
The note should contain the exact literal text plain nu: \nu, with the backslash preserved.
The CLI appears to interpret \n as a newline inside content= values, even when the shell argument is single-quoted. The resulting note is corrupted and becomes:
plain nu:
u
	Obsidian version: 1.12.7
	Installer version: 1.12.7
	Operating system: Darwin Kernel Version 25.4.0: Thu Mar 19 19:33:09 PDT 2026; root:xnu-12377.101.15~1/RELEASE_ARM64_T8112 25.4.0
	Catalyst license: none
	Plugins installed: 3
	Plugins enabled: 3
		1: Latex Suite v1.11.0
		2: TikZJax v0.5.2
		3: Git v2.38.0
This also reproduces with other LaTeX-style control words that begin with \n or \t, for example \theta, \tilde, and \to. In those cases the CLI appears to interpret \t as a tab, so the note content is also corrupted.
I first noticed this through daily:append, but the simpler reproduction above uses append. So this seems to affect at least append and daily:append, and possibly any CLI command that accepts content=....
This looks like an extra escape-decoding step in the Obsidian CLI after shell parsing. Shell quoting alone does not prevent it.
Current workaround: avoid passing raw LaTeX or other literal backslash-heavy text through CLI content= arguments and edit the file directly instead.
The single quote is not something we support.
I agree, We do need to find a way to escape these control characters.
I have a question regarding this :blush: … but it’s somewhat off-topic as it concerns property:set :innocent:.
Would these include being able to pass null as a value for the value parameter of property:set ?
When I tried (Discord message), I couldn’t find a way to either write it properly (with my basic knowledge of zsh, in general) or escape it so Obsidian would see the value as an actual null and not a string.
I’m sorry if this is a ridiculous question :sweat_smile: … I just didn’t know if I should open a separate FR or BR about this :innocent:
I met with the same issue.
A temporary workaround is splitting the content at the \n and \t boundaries and using append inline:
obsidian append path="note.md" inline content="$\\"
obsidian append path="note.md" inline content="nu$"
