CLI: `obsidian eval` prints its result, then never exits (3 times, not reproducible on demand)
I can’t make this happen on demand. I’m posting it because it happened three times in two days and the circumstances look similar each time.
  1. Settings → General → Command line interface: on.
  2. Call obsidian eval from scripts against a running Obsidian, for example:
    • obsidian eval code="(()=>{ const a = app.workspace.activeLeaf; return JSON.stringify({ file: a?.view.file?.path }); })()"
    • obsidian vault="Obsidian Sandbox" eval code="JSON.stringify({ hidden: document.hidden, size: [innerWidth, innerHeight] })"
Hundreds of calls over the two days exited normally. Three didn’t.
Did you read and follow the Troubleshooting Guide? [Yes/No]
Yes, as far as it applies: all three hangs were on Obsidian 1.14.4 with installer 1.14.4 (official installer). I’ve since updated to 1.14.5 (installer 1.14.5) and don’t know yet whether it still happens there. I can’t reproduce it on demand. One of the three hangs was a call to the sandbox vault (restricted mode on).
The CLI prints the result (=> …) and exits.
The CLI printed the complete result line, then kept running with no further output until it was killed: once after about 9 minutes (10 Oct), twice by a time limit, after 15 s and 90 s (11 Oct). Obsidian itself kept working, and the next calls worked normally.
This is not the | head case from topics 111691 (“CLI: command hangs when piping CLI output to the head command”) and 118581 (“Obsidian CLI hangs when stdout pipe closes early”): nothing closed the output early. It went to a file or to the calling program, which read it to the end.
Each time, an Obsidian window was on another macOS desktop (Space), or changing state, around the call:
  • 10 Oct: the active pane was in a pop-out window on another desktop.
  • 11 Oct, the sandbox call above: the sandbox window had just been brought to the front from another desktop.
  • 11 Oct: the call turned a pop-out window’s background throttling off (and back on 1.5 s later), and that pop-out window, on another desktop, disappeared at the same moment.
At the time of the hangs:
	Obsidian version: 1.14.4
	Installer version: 1.14.4
	Operating system: Darwin Kernel Version 25.6.0: Tue Aug 18 17:48:46 PDT 2026; root:xnu-12377.161.15.700.19~2/RELEASE_ARM64_T6041 25.6.0
	Catalyst license: none
	Main window: hidden
	Community theme: Things 2.2.4
	Snippets enabled: 7
	Plugins installed: 23
	Plugins enabled: 18
	Main window hidden: if the issue happens in a popout window, please check whether it still happens while the main window is visible.
macOS 26.7.1, Apple Silicon. The CLI is /usr/local/bin/obsidian → Obsidian.app/Contents/MacOS/obsidian-cli.
Workaround: a wrapper that stops the call after a time limit and keeps its output (macOS has no timeout command).
Suggestions: exit once the result has arrived, even if the connection to the app isn’t closed cleanly; and a built-in time limit (for example --timeout 60) with its own exit code.
