Simple search and replace only works within a single file.
Imported text files have unwanted strings, like these:
[ ]{.Apple-converted-space}
(with a varying number of spaces between [ and ] )
and these:
[]{.s1}
which are sometimes wrapped around strings that I want to keep:
[INSERT DATA {]{.s1} (should read INSERT DATA {)
I don’t know why these strings appeared because they weren’t evident in the original files, but I’d like to know whether there is a way to clean these up. I don’t really want to individually visit over 1000 documents if I can avoid it.
This is not a solution using Obsidian, but I found that Visual Studio Code’s Search & Replace functionality is pretty versatile and might do exactly what you need (make backups!):
Open folder in vs code
Open Search in Sidebar
Search for your pattern (you’d probably want a search with regex?)
Press the little arrow to show the replace dialogue
Enter your replacement (which is probably nothing, so leave it empty)
You’ll be able to see what it is going to do in the search results below
Press the replace all button and wait until it is finished
