Steps to reproduce the bug
- Open two tabs (notes) side by side like so where one note (tab) is linked in the other note (tab). In this case, I picked the note [[No prior experience]]
- In the second tab, add a link to [[No prior experience]] at another location. I’ve done so at the bottom here.
- Keep the second note scrolled to anywhere between the top and bottom of the note (this is essential).
- Change the name of the note in the first tab.
Yup. Used the sandbox vault.
No change whatsoever apart from the two links to [[No prior experience]] in the second note/tab getting updated.
If your scroll position is not at the top or the bottom of the note, the note jumps to the first instance of the link to the note who’s name you changed which is inconvenient when your note is very long.
Obsidian version: v1.6.7
Installer version: v1.6.7
Operating system: Darwin Kernel Version 21.6.0: Mon Jun 24 00:56:10 PDT 2024; root:xnu-8020.240.18.709.2~1/RELEASE_X86_64 21.6.0
A video of the bug being reproduced in my MacBook in a sandbox vault.
a onedrive link, lemme know if it doesn’t work
