Changing callout icon without changing the color?
Hey all, I want to customize my callout’s icon, but I want to have the same colors as other callouts, and since themes change the callout colors, I wanted to “inherit” the colors from another callout type. Is it possible?
For example, I want to have an info callout (same colors as info in any theme I use), but with a phone icon.
Also, is there an easier way than using custom CSS snippets? I like the way admonitions define icon and type, this could be a good addition to Obsidian.
Thanks!
You can use callout metadata for something like this to add the phone icon to any callout. e.g.
.callout[data-callout-metadata="phone"] {
    --callout-icon: lucide-phone;
Written as:
> [!info|phone]
> Contents
> [!warning|phone]
> Contents
Thanks, that’s exactly what I was looking for!
I believe this is missing from the docs, couldn’t find this anywhere.
Thank you!
https://help.obsidian.md/callouts#Customize+callouts
The customization section or the entire doc about callouts doesn’t include anything about metadatas
