On iPhone 18 Pro Max (iOS 27-01) in Obsidian App only:
Open any note and type using Gboard or EFy keyboard.
Type “home”, then change it to “Home”, either by tapping the capitalized suggestion in the keyboard suggestion bar or by cycling case with the Shift key (EFy) and “Home” is deleted and cursor moves to beginning of line.
Same happens with “end” changing to “End”.
It is the action of changing case to first letter capped that triggers the action.
Does not happen with default Apple English (US) keyboard text replacement.
Does not happen when I simply type “Home”, “HOME”, “home”, “End”, “END”, or “end”.
Note: using Wordboard app to directly enter “End” or “Home” triggers cursor movement as well.
Did you read and follow the Troubleshooting Guide? Yes
Simply change case without triggering an action.
PC Keyboard action occurs, meaning Home key or End key.
SYSTEM INFO: Obsidian version: 1-14-5 (387) API version: 1-14-5 Operating system: iOS 27-0-1 (Apple iPhone18,2) Login status: logged in Language: en Catalyst license: none Live preview: on Base theme: adapt to system Community theme: none Snippets enabled: 0 Restricted mode: on
Additional information None
