Captioned/Titled code blocks and single line copy button
I keep note pages with lots of example code blocks that I often copy and paste for penetration testing purposes. Such as common reverse shells, or other standard things that you type a lot.
For those I often use either a single line code block with some explanation for what it is like
this is some code (this is an expalnation)
Or
some code;
on multiple lines;
And the second case has a nice little “bash” button you can click to copy the code block to the clipboard
What I am suggesting is to allow for a more bolded caption to the multi-line code block like
some code;
on multiple lines;
Where it would display Stablizing Shell as a bold title for that whole code block
And it would also be nice to allow for a single line code block to have a copy button as well.
Currently, I just put descriptions ahead of the code blocks but this wastes visual space.
