When I use alt+click
to process embedded images and markdown files, the embedded links are fully selected. However, Canvas files behave differently, as they directly enter the Canvas editing interface, which affects the ability to quickly copy embedded links.
alt+click
![[Canvas]] is different from ![[image]] or ![[markdown]]
The alt+click
Canvas file should select the embedded link instead of entering editing interface, consistent with other embedded files
