Canvas: Move Labels on connection lines / offset connection lines
sometimes Labels on lines are hidden behind cards or lines are hard to follow
  • a way to move labels on the line path to a different location
  • offset lines with a control point
create a card and use it as a label and to offset path of line
I definitely agree! Here’s a similar request: Ability to select canvas group label even when beneath connection lines
Thanks!
