I use the word “edge” below to refer to the edge of a card or note, NOT in the graph theory sense. I’m calling those connections.
I’ve connected some cards and notes on a canvas. I haven’t really paid much attention to which rectangle edge I’ve used to start and end the connection. When I move the cards around the canvas, the connections are too curvy because they emerge from the wrong side of the cards.
Two proposals:
- right click a connection and select a menu item to minimize its length (pick two new connection points that minimize the distance of the connection)
- allow connection points in the center of a card or note. Perhaps you have to hold down a key to activate the center connection point to snap to it.
