Depending on the zoom level you can accidentally click the edge of a node an resize it rather than move it. When you have OCD and do not notice you did this immediately it turns into a mad session of resizing nodes to be similar.
Add a right click->Lock Dimensions, option for all types of nodes on a canvas.
Pay careful attention and hit ctrl-z when you do this.
I also would look for a feature like, this, and I’ll add my use case:
I build Canvas boards as a way to visually lay out my notes grouped by different areas of focus. I use them as “dashboards”. Once I lay out a “dashboard”, I still want to be able to easily edit/update the content within those notes from the dashboard, but rarely want to change the layout/sizing of the canvas cards themselves.
My use case calls for less granular control, but the following would possibly work
Adjust the global lock on a canvas to have a 3rd mode that locks the canvas layout, but still lets you edit the notes instead of being purely read only.
+1 for this feature. Canvas + Tasks + Dataview is a powerful combo for creating “Dashboards”, and I’d really like to be able to lock the layout/size of a set of cards so I can still edit these cards (including swapping the file for my daily note) but reduce faff of mistakenly moving around cards.
