Canvas card YAML frontmatter manifests as a blank first line in reading mode
Bug description
When viewing cards in a canvas, cards with YAML frontmatter have a blank initial line that pushes the start of the card’s actual content to the second line. This differs from regular notes, where YAML frontmatter is completely zero-impact in reading mode (i.e., two notes with identical content would appear the same in reading mode even if one of the two also had YAML frontmatter).
  1. Add a card to a canvas with at least one line of content (e.g., regular text)
  2. Add a YAML frontmatter section to the card
  3. Click out of the card to exit editing mode
Frontmatter section turns invisible in reading mode (i.e., when card is not being edited); its presence has no impact on the line positions of the card’s content.
Frontmatter section turns invisible in reading mode but appears to manifest as a single blank line before the card’s content, causing the content to begin on the card’s second line.
Obsidian version: v1.2.3
Installer version: v1.1.9
Operating system: Darwin Kernel Version 21.6.0: Sun Nov 6 23:31:16 PST 2022; root:xnu-8020.240.14~1/RELEASE_X86_64 21.6.0
Catalyst license: insider
Insider build toggle: on
Legacy editor: off
  • The screenshot below shows this behavior in the sandbox vault. The card being edited at the top becomes the bottom-left card when no longer being edited. Note the placement of the word “Text,” which is shifted lower compared to an equivalent card with no YAML frontmatter (bottom-right).
  • I’ve duplicated this behavior in macOS, iOS, and Windows.
Just to be thorough and sure, I repeated the test from the screenshot with properly formatted YAML and got the same result.
Anyone also seeing this or able to duplicate?
thanks
Same here. A minor issue but very annoying. Does anyone have a fix?
The issue happed more serious after I updated to v1.3.7
See as the picture:
I found a decent workaround using the Minimal theme with the Style Settings plugin but it does affect the styling of notes outside canvas.
Go to Style Settings plugin > Minimal > Text > and set Heading Spacing to 0 (default is 2em)
