  1. Move all tabs from the right sidebar to the left sidebar. The right sidebar will be automatically hidden.
  2. Split the current pane vertically, creating a new pane on the right side of the window.
  3. Drag the title bar icon of the new pane to the bottom of the window.
  4. Release the mouse button.
The pane should move to the bottom half of the window, underneath the first pane.
The pane you tried to move disappears and the right sidebar reappears. If you expand the right sidebar, it will now have a tab containing the pane you just tried to move.
  • Operating system: macOS Big Sur 11.4
  • Obsidian version: v0.12.4 (Installer version: v0.12.3)
thanks
will be fixed in 0.12.6
