This is dumb, but I can’t figure out how to switch to edit mode? I imported my vault, but it was set to preview. Now I can’t find a button to switch to edit.
Thanks!
Users tap the icon indicated on an iOS device…
Same on your mobile?
Angel
No, that’s not there. I’m also on Android, but I feel like that should still be there. I’ll check the plugins, but I’m not sure I have anything that’d remove that.
Thanks!
Hope an Android user can help.
Angel
I think it might be the plugin “Hider”, but it would let me uninstall it…
Just installed Hider to see what happens…
With Hider activated on an iPhone, you can swipe down on the middle of the screen to open the Command Palette. Type “pre” for “preview”, and there is an option to toggle between preview and edit modes. Same on Android?
Angel
Ah, yes, that works, thanks :slight_smile:
Good to hear. Welcome.
Angel
