Can’t bind hotkey to ctrl+shift+0
  1. Go to settings > Hotkeys
  2. Try to bind a command to this hotkey: ctrl+shift+0
Nothing happened, no error message, and the hotkey stays unchanged.
It’s weird that it works for ctrl+0
Also tried in the sandbox vault
Being able to use this hotkey to run commands.
Nothing happen
	Obsidian version: v1.5.12
	Installer version: v1.5.3
	Catalyst license: insider
	Plugins installed: 0
	Plugins enabled: 0
I want to reproduce Notion and other editor shortcuts to change text formating (different heading levels, bullet list, checklist, and reset formatting). They usually take the form of a ctrl+shit+number hotkey.
