Bug with formatting inside code blocks
  1. Create a new file.
  2. Start writing the following:
1. foo
3. bar
Yes
1. foo
3. bar
1. foo
   2. bar
Was able to reproduce in 3 different vaults across 2 different machines, this is for one of them:
Obsidian version: v1.10.6
Installer version: v1.8.10
Operating system: Darwin Kernel Version 24.6.0: Mon Jul 14 11:30:29 PDT 2025; root:xnu-11417.140.69~1/RELEASE_ARM64_T6000 24.6.0
There is a big chance other markdown-related autoformatting will also be triggered inside code blocks, while those should stay strictly raw without any processing.
Ok, first time using discourse in a long time, by “the following” I meant a code block with text inside:
1. foo
3. bar
Which then gets autoformatted inside the code block (obviously, autoformatting outside of it is fine)
Continue here:
