[Bug] `Vault.copy()` incomplete definition
Vault.copy() according to the docs
has the following signature.
copy(file: TFile, newPath: string): Promise<TFile>
However, based on its implementation and internal usage, it seems it also works for TFolder.
For example, Make a copy context menu action calls the same function for both files and folders.
I suggest the definition could be
copy(file: TFolder, newPath: string): Promise<TFolder>
copy(file: TAbstractFile, newPath: string): Promise<TAbstractFile>
// or
copy<T extends TAbstractFile>(file: T, newPath: string): Promise<T>
A little context in case it helps:
This was reported here on Discord.
Not a bug, this was just changed in 1.8, and we haven’t released the new API definition yet.
