[Bug] Settings: `number` control item validation not cleared after correcting input
With the new Settings Definition API, after inputting a number that is outside the defined range, if the then user corrects the value to be inside the range, the warning is not cleared.
Steps to reproduce:
  1. Add a control element of type number to your setting panel
    (For example using snippet from Docs - Settings#Number)
      name: 'Cache size (MB)',
      control: { type: 'number', key: 'cacheMb', min: 1, max: 500, defaultValue: 50 },
  2. In the rendered settings panel, change the value to a negative number and click outside the input element to trigger validation (eg. -1)
  3. A warning will display Value must be at least 1 as expected.
  4. Change the value back to a positive number within the valid range and click outside the input element to trigger validation (eg. 99)
  5. Observe that the previous warning remains.
  6. Optional; Confirm data has been saved in plugins data.json file
    Note, the input is not saved in step 2 due to failed validation, however it is in step 4 when the input is valid (as expected).
Thank you, this will be fixed in 1.13.5
