I am an enthusiastic user of Obsidian and so I was very happy about the new release. But unfortunately I think I found a quite annoying bug that make using Obsidian nearly impossible.
The bug
For some words the backspace key deletes backwards. If I understand right, then insert mode would delete the next characters, but in my case the last character or characters are deleted. And only for some words.
Examples of the words deleted
Some similiar words like rückwärts do not make problems.
My set up
I use Samsung S4 tablet with Android. I installed quite some plugins and use minimal theme. The mistake only appears with the external bluetooth keyboard RK908, not with the onscreen keyboard.
What I tried to change it
I turned off all plugins and changed the themes (to stand theme and others). I restarted the tablet. I cleaned the cache from Obsidian. I deinstalled and re-installed Obsidian. I tried other vaults. I made sure that spell check is deactivated. I changed the language setting.
But nothing helped. Therefore I ask for help from you. Or some suggestions what else to try? If you need more information from me, then let me know. Thanks for you attention and help in advance.
