Obsidian Mobile version: v1.4.1 (83)
API version: v1.0.3
Hello there,
Lately,I mentionned into this [Feature] topic, a bug that happened a couple of days ago :
Hi there,
Actually, yesterday, when using Obsidian mobile to do some minor editing to a note (“Mu”), this very one happened to be pinned into the right sidebar !
In this very same topic, another user, Cawlin, mentionned the same kind of bug, but into the left sidebar.
He suggested as a first solution to edit the .obsidian/workspace-mobile.json in order to remove the unexpected/unwanted item manually.
Is this possible through my desktop device, by allowing the access to this workspace-mobile.json in the desktop vault .obsidian folder via Sync for instance ?
Are those kind of notes jumps into sidebar happened through some features i would have activated by mistake in Obsidian Mobile ?
Thus, could i fix this situation (i.e. remove the note from right sidebar) via some current features (or soon to be upadted) i would not be aware of ?
Thank you very much for your enlightments, and have a great day.
D.
I have the same issue. My theory is that it has happened because I had the sidebar opened in the app, then I used a shortcut to launch the daily note, which got opened in the sidebar instead of the main pane. I was using the URL scheme for obsidian natural language dates with the “new pane” option set to “no”. I even have notes in both sidebars–the left and the right!
