Platform
Android A12
[ ] iOS
[x] Android
Obsidian Mobile version: v0.14.15.
Launch takes over 15 seconds, particularly the plugin load. It did not always do this.
Android A12
[ ] iOS
[x] Android
I’m running Android 12, Obsidian version: 0.14.15 my Obsidian startup time is about 4 seconds. I will tell you that I only run 5 plugins on android. Most of the ones I run on Linux don’t make a lot of sense to me on android.
Have you tried turning on “Debug startup time” to see which if any plugins may be causing the issue.
