[BUG][HELP] Escape touch eratic behavior
Hi all, I do a plugin and I have an issue with the escape touch.Everytime it’s tape, obsidian change leaf/tab.
For example , I took the code from the api (same issue than in my plugin but simpler to underxtand). I just change vgetLeaf.
Here the plugin. It create a new leaf and show. BUT when I tape the esc touch, he change leaf (change tab…)
I have the same behavior in my plugin and don’t understand why; The thing is that I need the escape touch (to excape suggessionbox, and everytime, obsidian change leaf and goes to another tab. anyidea ?
to reproduce:
(after created the pklugn )
  • a md file as normal
  • click on the dice → open a tab with example view.
  • tape escape. → goes to the md file tab…
What is the best and simple way to open registerfile (balbal.xxx) as it’s done for md file and so on?
thanks a lot for you help.
import { Plugin } from "obsidian";
export default class ExamplePlugin extends Plugin {
  async onload() {
    this.registerView(
      VIEW_TYPE_EXAMPLE,
      (leaf) => new ExampleView(leaf)
    this.addRibbonIcon("dice", "Activate view", () => {
      this.activateView();
  async onunload() {
    this.app.workspace.detachLeavesOfType(VIEW_TYPE_EXAMPLE);
  async activateView() {
    await this.app.workspace.getLeaf(false).setViewState({
      type: VIEW_TYPE_EXAMPLE,
      active: true,
    this.app.workspace.revealLeaf(
      this.app.workspace.getLeavesOfType(VIEW_TYPE_EXAMPLE)[0]
import { ItemView, WorkspaceLeaf } from "obsidian";
export const VIEW_TYPE_EXAMPLE = "example-view";
export class ExampleView extends ItemView {
  constructor(leaf: WorkspaceLeaf) {
    super(leaf);
  getViewType() {
    return VIEW_TYPE_EXAMPLE;
  getDisplayText() {
    return "Example view";
  async onOpen() {
    const container = this.containerEl.children[1];
    container.empty();
    container.createEl("h4", { text: "Example view" });
  async onClose() {
    // Nothing to clean up.
