Platform
[ ] iOS
[x] Android
Obsidian Mobile version: v1.0.2
Hello, I’m trying to open a vault that I have synced via Syncthing and I keep getting “Error: File does not exist”, which up until now wasn’t a problem when using Markor.
If I copy the synced folder into a new location I can reach it, which tells me it’s not the “odd characters in names” bug. The workaround I found is to copy, delete the original and rename the copy to the original name; that way Syncthing has access as well as Obsidian.
Obviously this is not a good way to go. I’m not sure what might be going on with this. My synced folder in cellphone is at /storage/emulated/0/Documents/vault with Syncthing v1.18.0, if it’s any help.
Thanks in advance
