We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
it is not a problem in itself and maybe it is more of a plugin idea but…since i have problem with obsidian jumping across the note it can help with that too.
it would be nice if we could add a bookmark to the side of a note where the number for the block shows.
i can write down the number of the block i was working at as a yaml metadata
