Bold doesn’t render inside highlighted text
When a larger selection of text (e.g., a sentence or paragraph) is highlighted with ==, smaller selections of text within it surrounded by ** are not rendered as bold, even though such selections surrounded by * are rendered as italic.
For example:
==Tested with the **default** theme as well as *Minimal*.==
Weird, for me it’s working. Have you tested also in restrected mode without plugins ?
Works for me as well.
Screenshot 2024-01-30 081517
Bug reports need the debug steps followed and the bug report template included. Thanks.
Moved to help.
I’m always telling people to turn on restricted mode, but I didn’t eat my own dogfood. I figured checking it with the default theme would be enough, but it wasn’t
The problem is the Highlightr plugin. I’m going to disable it and try it again when/if there’s an update.
Thanks!
