I have a mark-down file with block references.
 [[Page-In-Question#^06b7b8]]
In preview, it shows as expected. When I try to export with Pandoc:
 pandoc -s -o newFile.docx "MarkDownFile.md"
It produces the above verbatim in the word doc.
I am trying to export my finished piece as rtf or doc as I need to further refine it. Before obsidian, I would use a mind map and add notes. Then I could export that into a word doc for refinement. A pdf does not work as it does not cut and paste into word or other tools I use for further refinement. Any ideas?
Anyone?
What has worked for me is exporting to pdf and uploading it to Google Drive, right-clicking the file and then > Open with > Google Docs.
Layout does not always translate 1:1, but you can tweak your theme’s css to minimise indents from transcluded notes (search for ‘flush embeds’).
Thank you. It would be nice if they would offer a way to export from obsidian to other formats like rft, doc or html.
